Anyone know what Yamaha spring I can use in replacement for the white heel clicker spring that comes with the drag n flys ? also looking for some alternative to the screws and washers ? Would buy a set if someone had them ? sled is a 2009 RTX
I like running the ppp spring, you will need less weight in the arms than with white spring probly in the 62-63 gram area and i load base heavy with open tip. 1/4×28 button head bolts for arms and the heel is metric can't remeber what it is now. These will wear in the 3 cyl. Sleds pretty fast but run well in the 4cyl.
