**sj**
run the white spring..
4.3 grams in the heel..
5.2 grams in the center
0 in the tip..
3.2 in the overdrive..
comes in around 4k..
stock secondary on a non attak machine
0 in the tip..
Charged RTX
Have you run it back to back with the 2 speed. What make you think they run strong?
**sj**
never back to back...did some two speed testing yesterday...
need a cabin up north so I can spend a full day testing
tell you what they remind me of...all the goodness of the original heelclickers and then some....now that I think I have the 2 speeds dialed in I'll hope for snow and do some back to back
SharkAttak
are these the stock weight's? or super tips
**sj**
these are the newest ..in my opinion ...most highly engineered weights on the market...the heelclicker drag-n-flys....by super torquer..
Charged RTX
Is the overdrive that little bolt hole that hangs off of the end of the arm? Do they shift flatter than the 2 speeds. I assume yes if you have weight in the "overdrive" .
**sj**
the overdrive is the hole on the backside of the weight...
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Got a pic of what they look like?
**sj**
go to www.supertorquer.com ...I think theres a pic there?
87gtNOS
- Nov 30, 2005
- Toronto
sj said:go to www.supertorquer.com ...I think theres a pic there?
nope
DoktorC
87gtNOS
- Nov 30, 2005
- Toronto
assist...DoktorC said:http://www.richmotorsports.com/store/view_product.php?product=SUP2GXXO48
Look alittle weak on the heal...
**sj**
billet steel dok
- 6K
- 146K
