Charged RTX
My brother in-laws track does not seem align properly. No matter what we do it always runs at an angle from the left in the front to the right in the back. Is there enough slop in the chaincase and/or speedo bearing bracket to cause the track to run like this. It seems as though if it was off just 1/16th it would really effect the track alignment.
MadMax
Has he ever hit anything real hard????????? Make sure that both sides of the susp. is adjusted the same.. Shocks,transfer rods etc.. Then loosen the track way up and start adjusting 1/2 turns out at a time.. Good luck. MM.
LazyBastard
Three guesses;
1) The drivers are too far to the left.
2) Something in the suspension is bent - check main arm.
3) Something in the suspension is WORN or out of position - check main arm bushings, check that tunnel bolts haven't migrated.
welterracer
Make sure the bearings are O.K... one could be totally gone..
Len Todd
If I got this pictured right in my mind, has Speedometer side Bearing been reaplced lately?
