snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hi,i tried to look up bearing on Babbitts and port Yamaha and could not find P/N for stock bearing that has been spinning in race,and around 3000 miles may become a problem. Canandale (steve) showed how to peen it to stop spinning,and I thought he had a USA made bearing to replace it with,does anyone have info on that? And what is the procedure for removal of that bearing,it looks very tight down there behind the brake rotor.
Pstn head
I'm not sure the American made bearing P/N...but to remove and replace that bearing that whole aluminum part holding the caliper, and housing the bearing, (no idea what it's called) needs to be removed from the machine and the old bearing pressed out.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
The best way is to remove the 3 bolts from the back side which hold the brake and bearing carrier assembly to tunnel. With that out on the bench remove snap ring which holds bearing in housing to remove and replace bearing. If axle shaft spun inside bearing you may need to replace axle shaft. I had to replace mine as the axle spun to long and wore beyond repair. I knurled where bearing rides on axle to tighten up clearance. Not sure if peening will work in all cases as is will be determined by wear on axle surface. I have replaced mine twice in 9,000 miles. Need to service this bearing at least every 2,000 miles as my replacement bearing was gone again at 3,200 miles. Yamaha part number for bearing is 8JP-RAG06-00-00. Here is a picture of knurled bearing which tightened mine up so axle will fit snug in bearing so bearing will turn as designed.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
OK thanks guys,ya I did find that bearing P/N once I looked under brake assm. so I should be able to remove this bearing in housing and not remove track and take shaft completely out.The best way is to remove the 3 bolts from the back side which hold the brake and bearing carrier assembly to tunnel. With that out on the bench remove snap ring which holds bearing in housing to remove and replace bearing. If axle shaft spun inside bearing you may need to replace axle shaft. I had to replace mine as the axle spun to long and wore beyond repair. I knurled where bearing rides on axle to tighten up clearance. Not sure if peening will work in all cases as is will be determined by wear on axle surface. I have replaced mine twice in 9,000 miles. Need to service this bearing at least every 2,000 miles as my replacement bearing was gone again at 3,200 miles. Yamaha part number for bearing is 8JP-RAG06-00-00. Here is a picture of knurled bearing which tightened mine up so axle will fit snug in bearing so bearing will turn as designed.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Do you need to remove the bottom plastic skid plate,the piece riveted on,in order to remove all the parts to slide caliper and housing off?I'm not sure the American made bearing P/N...but to remove and replace that bearing that whole aluminum part holding the caliper, and housing the bearing, (no idea what it's called) needs to be removed from the machine and the old bearing pressed out.
Pstn head
Track and shaft do not need to come out.OK thanks guys,ya I did find that bearing P/N once I looked under brake assm. so I should be able to remove this bearing in housing and not remove track and take shaft completely out.
No. The key to getting the disc and caliper off is patience and only use hands. In and out and wiggle repeat. The disc puts a burr on splines by clip that can be difficult to get disc over. Be patient and don't force it or it can jam on there badly. I got 8000 mi from stock bearing which I cleaned and regreased every season. Was replaced with entire caliper under warranty when pads wore a big groove in caliper because they slide on the aluminum rather than a stainless insert like a proper caliper has.Do you need to remove the bottom plastic skid plate,the piece riveted on,in order to remove all the parts to slide caliper and housing off?
Pstn head
It's not necessary, but it's a hell of a lot easier... Plus you can do the rivet nut modification while your at it.Do you need to remove the bottom plastic skid plate,the piece riveted on,in order to remove all the parts to slide caliper and housing off?
Once disc clears shaft there is a cutaway in caliper to allow it to slide out.
Pstn head
Oh! And loosen track off, it'll reduce tension on driveshaft.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I repacked my bearing last year and it's not a bad job. I did have to split the caliper to get the rotor off and if you at planning on replacing the bearing this would be the best way to do it. After you split the bearing you can take the bearing and one half of the caliper over to your bench and remove the bearing.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Awsome,thats what I wanted to hear.Track and shaft do not need to come out.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes,thats what I was thinking to,have you done the rivet nut mod. if so where can I buy the kit to do both sides with? Thanks PeteIt's not necessary, but it's a hell of a lot easier... Plus you can do the rivet nut modification while your at it.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Are you talking about the case that holds the bearing steve,looks like there are 3 screws holding the plates on around the bearing,and two screws holding the caliper togeather,once the lg. circlip is out,do you press the bearing out of case than?Once disc clears shaft there is a cutaway in caliper to allow it to slide out.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Good advice,i may have forgot about that trick... ThanksOh! And loosen track off, it'll reduce tension on driveshaft.
