Custom Rx1
- Jan 16, 2007
I run the ECP kit with half the filter taped up so it is not lean on the bottom end. At wide open i see only 9000 to 9500 rpm, when i hold it i get flame out and it backs out, i let it go back to half and it picks up agin, what could the cause be?
This Kit Eats the new 07 REV 800 R race sled....
SUPERTUNER
blue rocket said:I run the ECP kit with half the filter taped up so it is not lean on the bottom end. At wide open i see only 9000 to 9500 rpm, when i hold it i get flame out and it backs out, i let it go back to half and it picks up agin, what could the cause be?
blue rocket...You are running too rich with half the filters taped off. Remove them and install the pre filters. If need be go to a richer pilot jets and move the needle clips down on the needles 1 position.
Freddie
Custom Rx1
- Jan 16, 2007
Freddie
Do you mean down to colse off the fuel? I have the filters instaled. The kit rocks.
Freddie
SUPERTUNER
blue rocket said:blue rocket...You are running too rich with half the filters taped off. Remove them and install the pre filters. If need be go to a richer pilot jets and move the needle clips down on the needles 1 position.
Freddie
No what I mean is if you think you are lean go to a bigger pilot jet. The reason why you are not able to pull any RPM is because you are way too rich with the filters half taped off.
SUPERTUNER
Freddie
Have made any headway blue rocket?
Freddie
Custom Rx1
- Jan 16, 2007
Not yet. I just took it out of my 03 and put it In my 04 warrior. Put 175 mains in. Have to buy a clutch kit this year for the kit.Thanks I will keep every one posted
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
Who sells the Dynarex's EVAC kit? Freddie!
SUPERTUNER
JROCK
- Oct 25, 2007
- Ottawa, Ontario
Thanks Freddie!
