Custom Rx1
- Jan 16, 2007
SUPERTUNER, has the best kit. I want to make sure that everyone knows that every sled is different. So if your kit is not running right it will. Supertuner helped me fix my own. I had a lean spot in the low end and could not fix it. He pointed me in the right direction. I put 22.5 piolts in and problem fix. See what the problem was is the stock pilots were clog with crap. Thus the lean spot. Do not be worryed about getting the kit, IT ROCKS.
I pull any stock sled on the snow and some mod sleds too.
Thanks to all
Ryan
Thanks to all
Ryan
SUPERTUNER
blue rocket said:SUPERTUNER, has the best kit. I want to make sure that everyone knows that every sled is different. So if your kit is not running right it will. Supertuner helped me fix my own. I had a lean spot in the low end and could not fix it. He pointed me in the right direction. I put 22.5 piolts in and problem fix. See what the problem was is the stock pilots were clog with crap. Thus the lean spot. Do not be worryed about getting the kit, IT ROCKS.
Thanks to all
Ryan
Thanks Ryan!
Freddie
Anordlun
- Sep 17, 2004
Hi there.
I'm about to buy the ECP-kit and I've heard that you, Supertuner, might be able to deliver it (To sweden)...
Custom Rx1
- Jan 16, 2007
You should Pm SUPERTUNER, He will get you the kit.
- 46K
- 7K
