benjamingvsu
- Oct 9, 2007
- Stevensville, Michigan
- 2014 Viper rtx se
Can a factory turbo ecu be used on a stock na viper or not?
No
Yamadog
What factory turbo are you talking about ? A sidewinder ecu?
Oh good question. Never thought of that.What factory turbo are you talking about ? A sidewinder ecu?
benjamingvsu
- Oct 9, 2007
- 2014 Viper rtx se
I meant the mpi turbo on the vipers. I found a used ECU for sale with the Evo rev limti changed. I thought it was from a mpi turbo sled, but it is actually from a n/a cat 7000.
Yamadog
That should work same exu as the viper
Is same as cat except cats have the pdi code enabled. It’s entered in the dash prior to delivery. I know it’s in ecu since guys have swapped dashes without issue. It should work as long as no one messed with that code or if you have code from original owner. We always wrote it on their paperwork.
