Engine Warranty using oil and low compression
update,
got to doing a leakdown test....#1 pto cyl 48% leakdown #2, #3 and #4 were all at 6-7%....can't hear air escaping anywhere exhaust or intake side...so ok found my problem now what is it??? did a compression test again and they are all 170-175 psi...so does this mean my oil ring on that bad cylinder is toast??...thats what i am thinking....also when doing the compression test the #1 cylinder builds pressure slower then the rest but still reaches 175psi...
