Hey guys,
My sled is giving me these error codes, anyone have any idea what the fix is for them?
It means the hose either came off or is plugged on the sensor that is attached to the airbox.Or the sensor itself went bad.
snomaniac
I had 14, it was a small hose from the throttle body to sensor plug. Take your head light off, as you are standing in front of sled look to the right corner of where head light was. You'll see a plug attached to your air box assembly, look below the plug( tight area) and you will see a small gray tube that goes from throttle body to plug bottom. See if either end is unhooked. Mine was unhooked from plug bottom. I believe 13 is the same thing but for sensor plug slightly to the left. If tubes are hooked maybe bad sensor plug as cannondale stated.One more thing, if it is a hose and you reconnect error code won't clear until you run sled and pressurize the system. Good luck.
Snowman35
What if it just comes on intermitently and then does not throw the code? Do you believe its the connector then?
