Fault code No. 60 Symptom Throttle servo motor: open or short circuit detected. Defective throttle servo motor. Malfunction in ECU (servo motor driving system).
the ty acessable manual says the same thing basicly.
my dad had an issue like that with a 09 silverado. the throttle plate would stick shut. dealer cleaned it 2 times but eventually had to replace it. you do not want oil on throttle plate pivots. i would clean them so the rotate freely with carb/intake cleaner 1st before going any farther on it.
