error code 84
grizzerly
Hillsdale, Ontario
i did exhaust donuts, y-pipes, connector pipe, plugs and oil. When i put together and try to start i get a code 84 and machine runs eratic. I can not get error code listed to download.
Code 84 is T.O.R.S
http://www.ty4stroke.com/viewtopic.php? ... light=tors
Check that link out. It explains what some other people did to correct that problem. You wouldn't happen to have messed with the driveshaft bearing lately and had the sensor or gear come off? That was the problem for a few people. Maybe check you throttle cables also to make sure that is bound up.
-Kyle
found issue
i had pulled lower throttle cable out of holder at area were idle adjuster is. Put back in and code 84 went away. Thanks for the replys
