kinger
I don't like the look of my EVAC you can see it on my avatar, I'm changing a few things around and I would like to see what others have. I have brand new filters and outerwear covers for them. Shoot me the parts list at a hardware store or just a nice picture of what you have that is nice and clean looking. Thanks!
sleddheadd
sent you a pm. kinger
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
I ran a tee into the catch can and used a short hose with a pcv valve in case the can ever got filled. So far has not happened, but would keep the sludge from going back into the carbs. I also have the velocity rings. Thanks again to Freddie, the sled "ROCKS"
culvert
Snowarrior... can you post a parts list of what you used to make your EVAC kit.
what size elbows and tee's where did you find the parts.
Thanks, Culvert
Thanks, Culvert
maxdlx
the T's are napa part #9924
the elbows 9934, might have thise backwards. 5/8 hose, andfor you Culvert. i have extra gromets, because I had to buy 5 but part # is 630-1079. I'll send you the gromets with the mony order. Paul
culvert
Wow, Thanks Paul.
That is great, I've been looking for parts to do this but everytime I hit the parts store the elbows are out of stock and none of them have grommets.
Now I can go to NAPA and order the right thing.
Thanks, again.
Thanks, again.
Sled Dog
Snowarrior where did you order your sno chargers for the filters and what part number are they? What jets are you guys running with the kit? Are you guys just drilling your holes in the filters end rubber and then inserting the grommets. If so what size hole are you drilling. Thanks a bunch.
maxdlx
I got my pre filters right from outerwears, part 20-1251. I used a 7/8 wood bit to drill the holes. I am running 165 mains at sea level. The gromets fit in perfect in the hole. I cut 2 small pieces(1/8 inch) of 5/8 hose and put it on the elbow fitings before sticking them in the gromet. Otherwise the elbow went in too far, and was sloppy in the gromet. I should have pics tomorow. Maxdlx
Sled Dog
Thanks Max the pictures will be helpful too.
Sled Dog
Here is the link to the evac parts and install.
http://www.totallyamaha.com/snowmobiles ... P/EVAC.htm
SnoWarrior
- Jan 13, 2005
- Long Island, NY
I bought the complete kit from Freddie, Supertuner, including the velocity rings. Sled runs like a champ, I like the sound and power.
maxdlx
only pic i have rightnow. i can't get the horns to stay on with the filters. Quess I need somekind of glue. But will get better pics tomorow or monday
culvert
MaxDlx-- did you get the springs and MJ's?
Still no money should be here this week, I hope.
SledDog--I'm up in Cold Lake, Ab. 17-2000' I'm running 162.5 MJ's, silver holtzman springs. Runs AWESOME. I found the sled ran boggy/rich with the 165's for riding around here. Bought the sled used and it came with filters on so dont know how much differnt it is, but it does run good.
maxdlx
Mike ys=es they are in there right now. If you don't get the money order Monday let me know. Paul
culvert
MAXDLX-- so you are using the stock air horns? I put mine on and thye seem to fit snug with no problems but havent fired the sled up and ran it to see if they vibrate loose or anything.
I'll let you know when the money gets here.
