DAGE
I was out yesterday and noticed the belt was slipping, I thought it was my secondary that wasn't tight enough until it got really bad, when I opened the hood and looked at the clutches they were covered in oil, I assume the evac hose froze up and blew oil all over the place, I've read that the oil comes from the valve cover gasket but my question is do I need to replace that gasket now or can I just unfreeze the hose and keep riding
Kyle
Kyle
SUPERTUNER
DAGE said:I was out yesterday and noticed the belt was slipping, I thought it was my secondary that wasn't tight enough until it got really bad, when I opened the hood and looked at the clutches they were covered in oil, I assume the evac hose froze up and blew oil all over the place, I've read that the oil comes from the valve cover gasket but my question is do I need to replace that gasket now or can I just unfreeze the hose and keep riding
Kyle
The rubber valve cover gaskets are reuseable. I wouldn't bother replacing it. If you loop your evac hose upward over the filters condensation and water will not be able to get in there and freeze.
Freddie
DAGE
SUPERTUNER
Yamaha's fix for RX1's that push oil is to put a slit in the hose as low as possible. The only thing I see that doing is making amess of your bellypan. Looping the hose up like in that picture will prevent to oil from travelling up due to gravity.
DoktorC
I left the slit in mine....until I noticed it was oiling the front of my engine compartment...and my primary. I've since sealed the slit and everything works fine.
manitoba rx1
My set-up came with a down spout on the T so that you can open a valve and let water out while it's warm...no idea if that's a god thing or not, but it works as far as I know. I did however remove that little silencer/air box that comes off the evac....would that affect anything?
