RylanB
- Dec 4, 2019
- penhold alberta
- 2018 arctic cat king cat m9000
i have the evo stage 4 tune and iam currently maxing out my 15lb boost guage to probably 17 or 18lbs . should a guy be putting head studs ? if so what length of arp studs?
Jakeshupe79
- Oct 11, 2017
- Grace
- 2017 yamaha sidewinder evo tuning
You don't need head studs at that boost. I'm running 24 psi without them. Have been for 2800 miles with no issues.i have the evo stage 4 tune and iam currently maxing out my 15lb boost guage to probably 17 or 18lbs . should a guy be putting head studs ? if so what length of arp studs?
RylanB
- Dec 4, 2019
- penhold alberta
wow ok sounds good !! thanks alot for your response. what tune are you running and hittin 24lbsYou don't need head studs at that boost. I'm running 24 psi without them. Have been for 2800 miles with no issues.
Jakeshupe79
- Oct 11, 2017
- Grace
Mcx 340 kit with my own custom fuel and boost map. I also have a king cat with the evo stage 4.wow ok sounds good !! thanks alot for your response. what tune are you running and hittin 24lbs
RylanB
- Dec 4, 2019
- penhold alberta
ok thanks thats awesome! interested to see this thing.
- 10K
