bitburner
- Sep 10, 2014
- 2013 Nytro XTX 1.75
Newbie here, first off I have to say how great this site is and thanks for all the info I've gotten.
I have a 2013 xtx 1.75, I just put the hurricane hindle kit on and there clutch kit as well. Now my track spins quite fast at idle. I shimed the three bolts on the back side of the secondary and now the belt sticks up about 1/8". I weighed the old weights and they were 60 grams and new ones are 58 grams and the springs I put in are the same as stock just new. Any body got any ideas?
So far I have the OFT relocate, star suspension kit, IP vent, dupont hifax, HID lights, foam added to seat.
1/8 seems like a lot what does the manual say
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Track creep is normal, but excessive speed isn't. Remove a shim washer on each of the bolts and run the sled to see if it's more to your liking. A new belt can cause this too.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Why did you shim the bolts? Was your belt loose?
I would take the shims out and see how it does for a start.
Also, put the sled on the floor or hold the brake for a better feel for if you have a problem or not before you do anything.
bitburner
- Sep 10, 2014
I will take a shim out and see how it works. The belt was put on and used all last season. I shimed it because the belt was sitting flush in the secondary.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
If you're still not happy with belt deflection, try finding a washer that isn't as thick as the one you remove.
bitburner
- Sep 10, 2014
The one I put in is thicker than stock so I will take the stock one out and leave the other one in and see how she goes.
bitburner
- Sep 10, 2014
Hope fully it works I don't want it driving away like my old fusion haha
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Check manual for the 1 mm belt deflection and idle rpm. They all creep while in the air. Do it on the floor.
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
Mine started to spin quite a bit faster after installing my clutch kit. It's not a problem at all! She's trying to tell you she's ready to rock and roll! If it bugs you put it on the ground during warmup or put on the e brake. You probably have on a new belt too, the track spin will decrease a fair bit when your belt wears down some.
Like said above, check your manual for proper deflection and belt ride height. It describes clearly what you want and how to measure it.
