JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
I removed my stock Hex bolts when new, tapped the threads in the turbo, used that Canadian Tire Nickle Anti Seize. In 1800km I've had the exhaust off 4 times and each time I did quick chasing of the threads and use the anti seize and still have the stock bolts, all is good so far
(Note I have the TD SuperQuiet Muffler and the one really hard to get bolt they don't use so that makes it a bit easier)
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
I use the Torx that came with it and the T50 Torx ball bit from Yamaha and run them out and in every couple of weeks (or during each thaw) and Moto Master 2500F anti-seize each time.What type of bolts do you use? Stainless or steel?
lilrez
- Feb 7, 2016
- Near Ottawa
So whats everyones thoughts on using typical exahust header bolts instead?? . 100s of differnet brands to chose from.... or.. has anyone considered studs...
Personally using oem fasteners, rocol and have no probs removing a couple times a year
RAMSOMAIR
I used metric flange bolts with ceramic never seez and never had an issue. Been off and on 4-5 times with over 5000km
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Locking exhaust fasteners, uses wedge type lock washer, I’ll tighten with vibration, works great I found them at Tommcat performance.com , hex head bolts.
- 6K
