09nytro24
Well that's that, bolts that hold the y pipe to the tunnel are stripped, now what? Can't cut them off, because they are indented inside the tunnel, drill them out? But then how am I able to bolt the damn things back together? What a joke, good job yamaha, great design.
drill them out that is what I did
09nytro24
How without damaging the threads?
09nytro24
Do I have to worry about drilling a hole in my header pipe if I drill these bolts out? I have so far broken 2 bits, and I am having a very rough time even being able to drill into these bolts, the must be hardened steel.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
No, the clamp where the two holes line up go between the header pipes. I will post a pic from my son's sled in a moment since his is apart replacing the donuts............09nytro24 said:Do I have to worry about drilling a hole in my header pipe if I drill these bolts out? I have so far broken 2 bits, and I am having a very rough time even being able to drill into these bolts, the must be hardened steel.
Apex2006
- Oct 26, 2009
- McHenry, IL
Here is a pic from my sons sled where the header is out sitting on top of the tunnel. You can see the holes go between the header pipes. You will have to drill out the studs by starting small and you may collapse the screw as you dril larger. Otherwise drill out and re-tap. I know it sucks right now but it really isn't bad if you have the right bit that drills through steel. Let me know if you need any other pics since my son's sled is apart waiting for manifold gasket to arrive.....
09nytro24
Thanks, I just went and bought some good drill bits, hopefully I can get it. The nut appears to be welded onto the bracket, correct?
Also, why did you take off the flex pipe?
Of course the dealer didn't have any donuts in stock...debating on ordering the copper ones from sledtoyz
Apex2006
- Oct 26, 2009
- McHenry, IL
My son wanted to inspect the flex pipes as well since his donuts were completely gone. Flex pipes were fine but want new manifold gaskets since we took them off. Copper is the way to go unless you can get stock over the counter to get up and running today, but they will need to be replaced in another 1500 to 2000 miles. Copper last way longer but you need to order them.
Apex2006
- Oct 26, 2009
- McHenry, IL
Yes, the nuts are welded... Ouch!
09nytro24
Wtf kind of bolts are these...smokes 3 brand new carbide bits and neither one of them are out yet...this is rediculous
Make sure when you're drilling steel to go slow and use lube. That may be why you're smoking bits?
09nytro24
This is absolutely rediculous, now what is the trick to get the damn y pipe out?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
I've only followed this for a bit but what are you drilling out? Don't need to to remove the the header. I removed the individual flex joints when I did mine
09nytro24
Yea I didn't do that...and now the y pipe won't come out...I thought the bracket on the y pipe was the portion that had the welded nut, but it appear to be a separate portion, which will just make this suck even more.
Is there a trick to getting this y pipe out? It looks like its sort of locked in there by the bracket riveted to the tunnel.
ALuCsRED
09nytro24 said:Yea I didn't do that...and now the y pipe won't come out...I thought the bracket on the y pipe was the portion that had the welded nut, but it appear to be a separate portion, which will just make this suck even more.
The y-pipe has to slide forward before it'll drop down from the bracket. The bracket underneath has fingers that hold the manifold up, and the fingers are pointed towards the engine. Hopefully that makes sense.
- 7K
