ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Can someone tell me if I can reuse the factory exhaust gasket from the turbo to muffler? I know to use the anti sieze on the flange bolts,but I think I saw some where you should not reuse the bolts,is this right?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
You can re-use the gasket, there's a post in the FAQ section about removing the exhaust, it's a good read. I replace mine with new hex heads everytime I remove them. I also chase the threads before installing new bolts.
