grumpysanta
I have a 05 rx1 er and the four header exhaust gaskets are shot. Do i have to remove the entire exhaust system to replace these donuts and what do they cost ? also is there any donuts at the connection from four to two pipes . tks.
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
Yes, You have to remove the seat, exahust caps and covers, then the exaust. Check my post....
www.ty4stroke.com/viewtopic.php?t=43237&highlight=
Make sure you soak the bolts under the seat....they are a bugger to get out. The ones towards the front I had to remove the bracket from the frame to get the bolt out. They rust bad.
My dealer gave me all new bolts for the motor flanges and new donuts under my YES warranty. Good Luck, if you have any questions, PM me
grumpysanta
thanks for the help
Do you have it apart yet? I thought my gaskets were shot on my '05 but it turned out to be both headers were cracked. Glad I had the YES.
grumpysanta
blown gaskets
all 4 are toast and there is no reason for this on a sled that costs this much . i have 11000km on mine but i have heard of guys with 2ooo km , having to replace them. what kind of life span is this, we would not put up with this with our cars,
rightarm
Re: blown gaskets
Usually they should be re-placed anytime the exhaust is removed,How long do you think they should last.11.000 kms is quite alot,if you owned that 2-stroke you would be re-placing alot more than $40 gaskets.
grumpysanta said:all 4 are toast and there is no reason for this on a sled that costs this much . i have 11000km on mine but i have heard of guys with 2ooo km , having to replace them. what kind of life span is this, we would not put up with this with our cars,
grumpysanta
blown gaskets
up here they cost 20$ each and do the exhaust donuts on your car need to be replaced also i have two bikes , a cbr 900 with 80000 km and no leaks and a fjr 1300 with 25ooo km and no leaks . so what is the differance...
grumpysanta
blown gaskets
another question ,,what are the two allen bolts under the gas tank for i loossened the clamp bolts uder the rubber grommets but having a hard time breaking the allen bolts loose / is it neccessary ???
rightarm
Re: blown gaskets
Extreme temperature ranges that your bikes never see,hot/cold,cold/hot.I apologize on the pricing didn't know the real value.Cars don't have donuts I believe they use one piece gaskets at the block/header?
grumpysanta said:up here they cost 20$ each and do the exhaust donuts on your car need to be replaced also i have two bikes , a cbr 900 with 80000 km and no leaks and a fjr 1300 with 25ooo km and no leaks . so what is the differance...
grumpysanta
blown gaskets
some cars esp. american made have donuts not at the head but from the end of the manifold to the first pipe and have had them for years
rightarm
Learn something new everyday,thanx GS.
SnoWarrior
- Jan 13, 2005
- Long Island, NY
Re: blown gaskets
Yes you have to loosen them so you can slide the headers back enough to get the donuts in. Those were the ones I could not get loose. I had to drill out the rivets and remove the whole bracket with the Y pipe still attatched. Then I used a vise grip to get the bolts out and replaced them. Then riveted the bracket back in. The clamp bolts under the gromets you loosen to pull the muffler and pipes out from the back of the sled. Then once that is out you have to slide the front assembly back by loosening those 2 allen bolts.
grumpysanta said:another question ,,what are the two allen bolts under the gas tank for i loossened the clamp bolts uder the rubber grommets but having a hard time breaking the allen bolts loose / is it neccessary ???
grumpysanta
blown gaskets
Thanks for all the info , mission complete . What a differance with no more rattle and no noise . A real job to get the muffler hooked back up to the secondary pipe , but a least i did not have to drill out rivets , lots of penatrating oil and patience . you would think Yamaha would engineer a better way than is complicated system , Two strokes shure have it easy . I hope they last this time cause i will sell it before i do this again..
