steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
Thanks. I do have studs. So they don't need to be super tight, just held in place. Makes sense. I will flip the screws around so just the pan head is exposed on the underside.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
exactly. sound perfect just make sure there are no sharp edges that the track could get caught/cut on.
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
Ok, this seems a lot better.
I had to pull the seat and just loosen the muffler and lift it a bit. There was enough play without forcing it up to let me get to the screw.
I was able to get to the rear screws by reaching up from inside the tunnel. Does this seem ok? Not sure I have much choices at this point, since I can't rivet, unless I fabricated some type of U bracket that held the tubes from the sides. I put it all back together though, as I'm pretty sure this won't present a problem.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Looks Great I would have no concern with that set up.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
That won't catch the track!
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
Right on.
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
Starry Knight
I'm undergoing replacing my donuts for the second time. Should have done them all when I had it apart last time! Biggest issue I have with the project is separating and reconnecting the muffler exhaust pipe from the 2 Y pipes. I have to beat it with a hammer so hard I'm concerned about damage. Any suggestions?
CaptCaper
- Jan 1, 2007
- Northern N.H.
what I have done many times is leave the front part of the system connected. i.e. headers etc to enging. Then loosen the clamps up good. Take a rubber mallet and tap the muffler back. Simple for sure. You can also wiggle the muffler around a bit to stretch open the joints but tapping is the ultimate resolve. In reassembly I use new gaskets on all parts. Cheap insurance. Hopefully it's your donut. I've had flex pipes go a couple of times. Take them off the engine and check the seams,etc. I cover one end also and blow hard to see if air leaks out.
