machz69
what is the best external drivers for an 06 attak?.. I'm looking at the Whal Bros. Would the bombs be better?.. what size of shaft does my 06 have?
AttakDog
I used the Wahls on my 06 Attak and they work good. Got them from Rich Motorsports, he knows the size
- Nov 23, 2003
The one's you need are the 1-1/16 to 1- 1/8. I have some if you need them.
Bruce
Bruce
schmeg
Ski-Doo Mach Z drivers work great. Good price. Need a press to do the switch.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
check classifieds....SPEED just posted some for sale.
Dan
Dan
MarkAttack
02-579…..No Slip 2.52” Pitch Drive Sprocket, 9T, 1 1/16”-1 1/8” Hexwhat is the best external drivers for an 06 attak?.. I'm looking at the Whal Bros. Would the bombs be better?.. what size of shaft does my 06 have?
$94.95 Looks to me like a 2006 has a 30 mm hex shaft which is closer to 1 1/16" the Newer models use 1 1/4"
02-574......No Slip 2.52” Pitch Drive Sprocket, 9T, 1 1/8”-30mm Hex (2009 Yamaha Apex, Vecture, Venture 121" & 136") $94.95
http://www.wahlracing.com/2.52-No-Slip-Drive-Sprockets.html
I plan to go to fully Clipped does anyone know what is the best tool to cut the windows out of the track ?
most guys use a carpet knife to cut open the closed windows when clipping a track. last one i did i use a hole saw as i was not planning on clipping the track.
MarkAttack
I was just thinking about the wood craft kit I had as a kid.. because I was going to make a joke about using a hot knife.. Yet a Hot knife would reduce bare threads and unraveling..
I have seen heavy duty carpet Scissors.. I need to google carpet knife.. I know a Box Cutter would not hold up .. You can never have too many tools ..
I can see that there are many variables to carpet knives. but I get the idea of the shape.. The cheap ones look like they use razor blades..
https://www.amazon.com/Morakniv-Cra...=2025&creative=165953&creativeASIN=B00E6OOGP6
https://www.amazon.com/Whetstone-Cutlery-Blade-Stainless-Folding/dp/B002I6C9ZS?
SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-d-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B002I6C9ZS
https://www.amazon.com/PIKAS-Don-Ca...-goods&sprefix=linolium+,sporting,215&sr=1-16
$10 or $54 and the cheap one is folding and Stainless
MarkAttack
Some one posted a Skidoo Part # can't get any specs or dimensions.. 2006 Yamaha Apex Attack was a 30 mm Hex shaft witch is around 1 1/16" in 2009 Yamaha went to a larger shaft that is closer to 1 1/8" or 1 1/4" I can't even find that out .. Just part # and photos .. Wahl makes two different part #'s the difference being the diameter of the hex and the pitch. 2.52 or 2.86 ectSki-Doo Mach Z drivers work great. Good price. Need a press to do the switch.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
I read somewhere that using a sharp chisel and hammer works good for cutting the windows out. Back the track with a oak 4x4.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
Driveshaft 06-10 is 27mm, after 11- it´s 30mm
If you are going fully clipped, all windows would be open....?02-579…..No Slip 2.52” Pitch Drive Sprocket, 9T, 1 1/16”-1 1/8” Hex
MarkAttack
Yes if you have say a 9 tooth Sprocket all windows have to be open.. It seems I saw a Sprocket that has an external tooth in every other position.. That would not even work on odd or even sprockets.. I must be wrong.. I just can't remember..
Some times say Yamaha uses an external drive with all windows open but still only 1 clip per third window.. More Clips = more steel on hyfax less friction cooler hyfax.. Some clips even have grooves in them to hold snow for when there is not enough snow to lubricate well ..
MarkAttack
I never head 27 mm mentioned before .. I converted it to 1 1/16" inch calculator did not do in thousandths 30 mm comes out to 1 3/16"
27 mm 1.062992 30 mm 1.181102 Wahl Bros lists the 2009 Models needed the 30 mm hex bore
