ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I have a brand new stock 2" 151 sitting in my garage to go on my 04 RX1 Mountain. I want to put extroverts on and cut the windows. I was told to put on dual driver extroverts and fully clip the track. First of all, is the chisel and hammer method the best way to cut windows?? Second, is clipping necessary? What extroverts should I buy??
Dazed and even more confused.
tmk50
The chisel and hammer method worked well for me - take the time to sharpen your chisels before you start. I didn't clip it and had no problems at all, so I wouldn't bother. I used the Wahl Bros extroverts and they worked fine.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
I also punched my track with chisel and hammer. I also skimmed over the track edges with a quick-fire propane torch.
It's better if you don't have to clip the track cause the taller lugs require a very expensive tool that can reach past them, or from undernieth. Channel-locks couldn't do it either. I borrowed a tool that got all the open areas, but I had to take the track to a Ski-Doo dealer, and they had to order a new tool cause the one they had couldn't bite hard enough. They charged me $25 for 36 and I supplied the clips.
BTW: I had my track out, and ran it through the legs of a saw-horse with a 2X8 deck.
Hookman49
RX1MPete said:I want to put extroverts on and cut the windows.
Pardon my ignorance, but what is Extroverts? :?
Ken
tmk50
Extrovert drivers for the track - they drive the track using the track windows.
Combination internal/external drivers drive off of the standard 'nubs' on the inside of the track and through the windows.
rideblue
- Mar 17, 2005
- Buena Vista Colorado
- www.mountaintechbv.com
I have a set of Wahl Bros combo sprockets for sale, 9 tooth for yamaha. Used for one season. I cut my windows out with a utility knife with and few new blades.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
What about using a holesaw?
Jonny Rocket
- Colville, Washington
- 2008 MXC boosted Nitro
I helped punch out a track and found the chisel method to work very well. I would have to agree with tmk50 on the sharpening part. When we started, the chisels were not very sharp and did not work very well. You have to make sure they are very sharp. Only took us about 30-45 mins to punch the entire track after we sharpened the chisels.
J.
J.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
I just punched out the windows from my track using a chisel and rubber mallet. It worked great! Thanks guys. Now, I just need to figure out the difference between 8 and 9 tooth anti-ratchet drivers.
whits-end
- Mar 2, 2004
I used the Wahl drivers, they're available as 'super drivers' from Royal D, but last year they were back-ordered for awhile.
Pressed on easily, and removes a fair amout of rotating mass, as the stock outer drivers have to come off, as well.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
Royal has no Wahl drivers in the 06 Catalogue. However, Royal do have Super Sprockets by Micro Belmont Engineering. $115 each. Yikes!
spray25
Jonny Rocket said:I helped punch out a track and found the chisel method to work very well. I would have to agree with tmk50 on the sharpening part. When we started, the chisels were not very sharp and did not work very well. You have to make sure they are very sharp. Only took us about 30-45 mins to punch the entire track after we sharpened the chisels.
J.
I just looked up "helped" in Webster's dictionary and it does NOT say "standing with beer in hand watching".
Yeah the chisels worked good. To clip the track we borrowed a home made tool that looked like a giant set of bolt cutters. You used it from the inside of the track. I left the track on to do it and that was a mistake. My arm still hurts!!
tundra
[/quote]
[/quote]
Here we call this ''mental support''
[/quote]
Jonny Rocket
spray25 said:Jonny Rocket said:I helped punch out a track and found the chisel method to work very well. I would have to agree with tmk50 on the sharpening part. When we started, the chisels were not very sharp and did not work very well. You have to make sure they are very sharp. Only took us about 30-45 mins to punch the entire track after we sharpened the chisels.
J.
I just looked in the "Jon" Dictionary and it actually states that "standing with beer in hand watching" is considered "helping"
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
Jonny Rocket said:spray25 said:Jonny Rocket said:I helped punch out a track and found the chisel method to work very well. I would have to agree with tmk50 on the sharpening part. When we started, the chisels were not very sharp and did not work very well. You have to make sure they are very sharp. Only took us about 30-45 mins to punch the entire track after we sharpened the chisels.
J.
I just looked in the "Jon" Dictionary and it actually states that "standing with beer in hand watching" is considered "helping"![]()
LOL... Watching and drinking beer, while sitting means "Supervising"
