- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Exup problems? Get rid of it!
https://shop.ulmerracing.com/Apex-O...htm?productId=-3687853&catalogId=-11683&fpg=1
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
I had this header on my ‘11 XTX and it was top notch.......great build quality, no more exup headaches, and required more fuel to be added in my PCV map, which means it was making a little more power too.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Yamaha wants $2,835.99 US price for a stock OEM replacement header for the 2011-2018 Apex models.
I have 13 of these aftermarket replacement headers left in stock yet, once this inventory runs out I do not plan on making any more. If you are thinking of buying one of these, decide soon before they run out.
Caveman
- Sep 13, 2012
- New Hampshire
- Yamaha, Polaris, SkiDoo.
Can I get it for the sale price you had running awhile back?
- Apr 17, 2003
- Menno, SD
- Menno, SD
No, unfortunately I can not do the sale price on this last batch of headers as the price of materials has risen.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
How much do they cost?
- Apr 17, 2003
- Menno, SD
- Menno, SD
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
So does this mean Exup is a failure and we're all better off without it? Were the benefits real or imagined?
72Gran
- Jan 25, 2009
- 15 Apex XTX
21 Sidewinder LTX GT
What are Exup problems??
I have 33500kms and no issue
Just lube the cable ends during oil changes with high temp anti seize and check adjustment, good to go.
20/80
Is there a easy way to lube the cables? or does all have to come apart to get to it.What are Exup problems??
- Apr 17, 2003
- Menno, SD
- Menno, SD
It's another thing to perform maintenance on and also the titanium pipe will crack over time (especially if you are a aggressive rider) or if the flanges crack due to a blown exhaust donut it's very expensive to replace the header.
You have had great luck with your stock exhaust system! Typically failures are donut failures resulting in broken flanges, cables stretched or broken, and overall titanium can or will crack where the 4 pipes go into 1 single outlet.
I've seen some not make it to 20000 kms and the header is done.
There's no doubt they add midrange rower. However, the Apex wasn't exactly lacking in that department as two strokes are soft in the low to mid range also.So does this mean Exup is a failure and we're all better off without it? Were the benefits real or imagined?
I feel that Yamaha would have been far better off bumping the displacement up to 1050, like they had in the marine department, instead of EXUP.
72Gran
- Jan 25, 2009
- 15 Apex XTX
The seat and gas tank have to come off, same for checking exhaust donuts. It’s actually very easy on this sled.Is there a easy way to lube the cables? or does all have to come apart to get to it.
72Gran
- Jan 25, 2009
- 15 Apex XTX
It’s just maintenance not luck. Exhaust donuts are a maintenance item and exup cables are a maintenance item. If you check them every oil change and replace as required my experience has been zero issues. My 08 has 50000kms and factory exhaust. The 08 got new donuts every oil change. The 15 got them every 15000, Yamaha made an improvement on these.It's another thing to perform maintenance on and also the titanium pipe will crack over time (especially if you are a aggressive rider) or if the flanges crack due to a blown exhaust donut it's very expensive to replace the header.
