1. We are no longer supporting TapaTalk as a mobile app for our sites. The TapaTalk App has many issues with speed on our server as well as security holes that leave us vulnerable to attacks and spammers.
    Dismiss Notice
F/S GYT Clicker Front Shocks, Apex/Vector
Discussion in 'Yamaha Parts and Acc.' started by dmaxx, Jan 13, 2020.
  1. dmaxx
    dmaxx VIP Member VIP Member
    382
    sw Michigan
    Country:
    Snowmobile:
    2012 Apex XTX, 2010 Vector LTX, 2000 AC Z-370..fast
    White Pigeon, MI
    I have a set of GYT front clicker shocks, 16.5" eye to eye. Currently mounted on my Apex. Will fit the Vectors also. In very good condition, do not have "GYT" stickers on them. $300.
  2.
  3. Gotrek
    Gotrek Newbie
    13
    Winterpeg
    Country:
    Canada
    Snowmobile:
    2008 vector rs l-tx
    EDIT: There is no stirkeout font but ignore this is wrong... :)
    Just FYI (And I know you probably know and took pictures while adjusting the shock but just in case) That other ring at the top of your shock should be lowered to touch the other one to lock it in place. (Just mentioning it since I see a lot of guys riding with the lock ring up like that.)
  4. twyztid
    twyztid VIP Member VIP Member
    332
    Middleville, MI
    Country:
    Snowmobile:
    2015 SR Viper LTX SE w/ MPI Turbo
    2006 Apex GT
    Middleville, MI
    That is incorrect. That "other" aluminum ring at the top stays there. On top of the spring you have a steel adjuster nut with an aluminum adjuster nut locking it. This is the way the ALL are including the 2 sets that I have.
  5. Gotrek
    Gotrek Newbie
    13
    Winterpeg
    Country:
    Canada
    Snowmobile:
    2008 vector rs l-tx
    Good to know (sorry new Yamaha guy) Almost all car adjustable shocks I've seen use that ring as a locking ring. What's the purpose of it?
  6. twyztid
    332
    Middleville, MI
    Country:
    Snowmobile:
    2006 Apex GT
    Middleville, MI
    I think looks only. If you look under the lower aluminum one, you will see a steel adjuster nut as well so there IS positive locking already there holding the spring preload.
  7. Gotrek
    Gotrek Newbie
    13
    Winterpeg
    Country:
    Canada
    Snowmobile:
    2008 vector rs l-tx
    Ok cool gotcha sorry about polluting your thread with chatter :)
    Edit: also thought after if the shocks are height adjustable they might have a locking ring up there.
  8. dmaxx
    382
    sw Michigan
    Country:
    Snowmobile:
    White Pigeon, MI
    They have the 2 locking collars in the proper place. As stated in reply, the top ring is stationary.
  9. Gotrek
    Gotrek Newbie
    13
    Winterpeg
    Country:
    Canada
    Snowmobile:
    2008 vector rs l-tx
    Yes I realize now that shock length is probably adjustable and that is the lock ring for the top.
  10. 2006Apexed
    2006Apexed Newbie
    5
    Wisconsin
    Country:
    Snowmobile:
    2006 Apex RTX
    Interested. How do they compare to the Fox Floats on my 2006 Apex RTX. I mostly trail ride and am 230 lbs. thanks
  11. dmaxx
    382
    sw Michigan
    Country:
    Snowmobile:
    White Pigeon, MI
    Great for trail riding, more adjustments possible.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
