jlinstruth
- Aug 13, 2017
- Chamount, Ny
- 2018 Yamaha sidewinder ltx se
Got 2 inches of snow so I was out trying to dial clutching in today. Only mod is a excell mod/stock muffler. After 50 different set ups all giving same basic results, I am looking for advice. Every set up up shifts aggressive to 89-9200 then falls back to 84-8500 where is stays for 1000 ft, some would fall as far 8250. Now with everything stock except muffler it's flat at 8550 forever.
@123
to much tip weight !!! take at least 3g outGot 2 inches of snow so I was out trying to dial clutching in today. Only mod is a excell mod/stock muffler. After 50 different set ups all giving same basic results, I am looking for advice. Every set up up shifts aggressive to 89-9200 then falls back to 84-8500 where is stays for 1000 ft, some would fall as far 8250. Now with everything stock except muffler it's flat at 8550 forever.
jlinstruth
- Aug 13, 2017
- Chamount, Ny
Yeah, stock weights, should turn rpms
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Need more info, what weights, springs, helix?
jlinstruth
- Aug 13, 2017
- Chamount, Ny
Stock weight, stock primary spring, stock 35 helix, stock secondary spring.
Acted the same with aftermarket clutching
Sled is 2017 ltx se
Sled is 2017 ltx se
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
How many miles on your 2018 sidewinder?
jlinstruth
- Aug 13, 2017
- Chamount, Ny
2017 winder, 50 miles
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Get some miles on it so it breaks in. These engines are pretty tight new. Your rpms should come up then.
DMCTurbo
- Nov 12, 2005
Did you run the sled with the stock exhaust first? Rpms?
What did u try for aftermarket clutching? I'd move some weight from the tip to the heel. Try again and see where you are at.
Only change one thing at a time and write everything down. Changing more than one thing at a time will make you chase your tail.
**sj**
did you buy the muffler mod at Excell???
Pstn head
you need afew miles
jlinstruth
- Aug 13, 2017
- Chamount, Ny
Yes, rpms before mod seemed fine, yes bought at excel, and for clutching we always write everything down, change one thing at a time. My real question is if anyone has needed fuel with the muffler mods. The sled really seems like its running out of fuel on top, seen same thing with modded skidoos ive had.
Pstn head
Well we rode with two 0 km Sidewinders last week and fom first start up to last run they both got more rpm and top speed as the day went on. I also experianced this with mine when new.I bielieve you need a little more miles and time. It will lossen up.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
Then it must be the muffler mod that is the problem.Yes, rpms before mod seemed fine, yes bought at excel, and for clutching we always write everything down, change one thing at a time. My real question is if anyone has needed fuel with the muffler mods. The sled really seems like its running out of fuel on top, seen same thing with modded skidoos ive had.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
There are only a few mufflers out there that don't need more fuel. Can't imagine a stock muffler mod not needing more fuel.
My bone stock 2017 LTX-LE ran 9000 RPM last year from start to finish with 100% stock clutching after broke in.
- 46K
- 31K
