Jqroc
- Dec 2, 2014
- Penfield
- Yamaha viper rtx se
Getting my sled ready for the winter and last year I noticed the fan wasn't working, turns out the fuse was blown, I changed the fuse and heated up the sled to see if the fan would kick on and the fuse blew again. I figure I have a bad fan but before I buy a new one I was wondering if anyone else had this problem or if they knew another reason why the fuse would blow. Thanks for any help.
Havent heard of anyone else but only other test you could do is unplug the fan and warm sled up see if fuse blows again. If it would then that would either be a short in wiring or the sensor. I would say if fuse did not pop then yes it must be the fan itself. Could also just jump the fan and see if it works.
Jqroc
- Dec 2, 2014
- Penfield
What would be a easy way to jump the fan?Havent heard of anyone else but only other test you could do is unplug the fan and warm sled up see if fuse blows again. If it would then that would either be a short in wiring or the sensor. I would say if fuse did not pop then yes it must be the fan itself. Could also just jump the fan and see if it works.
ViperBill
- Dec 14, 2014
- Linwood mn
- 14 viper rtx
I have the same problem. I removed it and its hard to turn prob rust in the motor shaft and bushings. They get wet often. It doesnt come apart and will have to be replaced.
It's a two wire plug. Run 12v power to one and ground the other. Could use jumper cables. Just be careful.What would be a easy way to jump the fan?
Warranty?
stingray719
In my opinion reversing the fan would not draw as much water through the fan, still lives in a wet area though.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
My fan died in less than 500 miles. Replaced under warrantee at the end of last season. Seems they must have gotten a bad batch of fans. Hopefully it wasn't replaced with the same batch.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Seams like these A.C. fans don't hold up to the environment very well? I never had issues with our older Japan Yamaha fans. Maybe adapt the brackets and use one of them if you don't have warranty left on your sled instead of buying a fan you know is going to fail again? I'm not sure what Japan model would have a fan about the same size but just a idea to kick around?
If I remember right it's a Spal fan. Those are good fans. Normally.
ViperBill
- Dec 14, 2014
- Linwood mn
- 14 viper rtx
Mine failed mid season last year. I removed it and without the restriction to airflow the fan and shroud creates I had no problems even at slow speed. I just did not let it idle for long periods. Not sure I will even bother replacing it.
stingray719
Agreed, fan usually only runs at stop or very slow. On our Blue Viper I removed the fan and radiator and run ice scratchers.
