13NytroXTX
- Sep 16, 2012
- Appleton, WI
- 2013 Nytro xtx
Last Friday I stopped to get gas and when I started up my sled code 85 was flashing so I shut it off and restarted it and the code was gone. It has done that a few times since so I always shut it off and restarted it and it went away. Today I stopped to get gas and when I started it the code was back and wouldn't go away when I restarted it. I rode it home with the code flashing all the way back. When I got home I shut it off, turned the key back on and the code was gone. Anyone else have this problem or know how to fix it?
- Jun 28, 2004
- Clinton, Wi.
If you look in the Nytro FAQ section at the top of the page, you'll find a listing for all the codes. Yours indicates an issue with your oil pressure sender. Might be a a bad sending unit, or could be as simple as a bad connection.
13NytroXTX
- Sep 16, 2012
- Appleton, WI
- 2013 Nytro xtx
Yea I played with the connection but that obviously didn't fix it lol
burgerbone
Mine started with that same issue. I thought it was the sensor so I changed it, no luck.
Don't want to get you worried but this is what happened to me.
13NytroXTX
- Sep 16, 2012
- Appleton, WI
- 2013 Nytro xtx
I hope that doesn't happen. I put on 140 miles yesterday and the light never came on
