osceolacabin
osceolacabin
osceolacabin
RoicIND
NICE!!!!
What did you do for a seat cover?
Custom tailored???
Custom tailored???
simonzsayz
lookz really good! Didn't know they had a dual exhaust. Is it true, like one for each cylinder? either way looks great, I like the black too.
Cool!
OST
Dammm nice sled you got there!
Love black sleds and that one sure looks killer!
Sled looks great. Now we just need some SNOW.
drrrd420
very very nice man, yet another black phazer to add to te club. rock on
osceolacabin
Thanks for the compliments, it was a fun project. Took it to the dealer this morning. The recall for the steering is new nuts and cotter pins. For snow intrusion into this area, they are putting on a deflector on the top/bottom. Also, torque on the left engine bolt is included. Think that was it...hats off to the dealer for getting the parts, should be done later today or tomorrow.
BTW, while greasing up the skid...noticed the left (as your sitting on the machine) upper idler has a flat spot. Dealer will look at it, see what Yamaha has to say...probably will be blamed on the studs... :ORC
osceolacabin
Forgot the new clips for the airbox...I had already drilled out the old ones, so we will see how that goes...
I just replaced both of mine. Warper and warn on an angle.
osceolacabin
zook said:I just replaced both of mine. Warper and warn on an angle.
I think you may be refering to the front lower inner idlers...saw your post on them. They warp pretty fast...not a stud issue.
I will give this to Yamaha and this dealership in particular, I am very impressed. With the quirks of the Phazer, I still love the machine...great engineering by Yamaha. The dealership is top notch, dropped it off this morning...early afternoon done. In addition they replaced the top two inner idlers (rear ones on the spring hanger) due to flat spots...under warranty. They have been great in responding to the issues, maybe not the answer I want immediately...but they take care of their customer.
Thinking about the upper idlers...I think they must have froze (water from the pipe...drip down...freeze) overnight. Then on start up they didn't start turning...check your upper idlers...
Will Do-- Thanx for the heads up.
osceolacabin
Picked her up an hour or so ago, all the recalls went well. Both the upper rear idlers (8GC-47530-01) were replaced by the dealer and they are going to Yamaha to cover them under warranty. It was not just one flat spot as thought, but multiple flat spots (3 or 4 areas). The thought between the dealer and I is the water from the muffler is getting down into that area and freezing...hanging up the wheels. It is not know if this happens after it sits overnight/lunch or during travel. Word of advice, check your uppers...
Real pleased with the dealership, this is the way it should be done...they definitely have my next sled purchase. They get you in and out quickly and go that extra step...
