rtx moose
- Jul 31, 2014
- WATERTOWN,MN
Took my 2000 srx out last night and noticed the lights were dimmer than usual then one of the two headlight barely worked..at our first place we stopped at.it would not start!!!!!pulled it over and no lights at all not even when engine turned over when i pulled..
Total bummer the srx has never failed in 19 years of owning it..im guessing my stator went out...what do you guys think?
whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
Agree stator
Stator
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
What, couldn't even go twenty years on that sled!!! Better switch brands!!!
But, actually, does sound like stator.
AftonJay
- Oct 23, 2012
- Northern Michigan
- 2005 Warrior, 2009 Nytro XTX and Arctic cat puma for the kids
- Afton Mi
Those Junk Yamahas!!
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
I'd be pretty happy to get 20 years out of sled without any problems. My vote goes to the stator also.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
How easy is it to replace?
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
Dammit...just went out to garage and decided to pull it over just for the hell of it and it started like new no lights dimmed either WTF HERE WE GO...so what would cause this?
whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
Could be a corroded ground but still think it’s the stator. Run it around close to home see what happens. Stators usually a catastrophic failure in my experience depends on what circuits are fried. Mine a 2s doa on the spot my buds got him home but that was a 4s Apex.
trail traveler
- Dec 3, 2014
- Everett, WA
- 2015 sr viper s-tx-dx
2014 Venture MP
2016 RS Venture
2017 sr viper x-tx
3- 1990's era Arctic Cat prowlers
I had an older 2s do this awhile back. It would start and run fine one day, and then do nothing the next. I was constantly checking for spark with various results. After switching out different components from other sleds with nothing making it better, I removed the stator. It was bad. Purchased a used one from a snowmobile junkyard on-line and that solved the issue. It seems this may be your case also.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
might be a rub-through in your wiring harness
some stators only act up when they get hot. at 19 years it would not hurt to replace it.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Those sleds were known for harness rub throughs under the motor. With my SXR I pulled the harness out and put a plastic sleeve over it. I think it's called wire loom.
On another note my son rode the 2001 SXR 100 miles last weekend with all of us and we never had to wait for him.
Sounds like a rub through. The 1998-2002 SRXs were known to have this problem.
Go to the 2 stroke forums and do a search "Rub Through" should be lots on info that shows up in the SRX/Viper forum
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
So this is the thing back in 2005 i had tbe YES WARRANTY. .i had the rub thru wire harness issue resolved by the dealer...so was the fix a reroute of the wiring or did they just replace?anyone know what the dealer fix was?
