hedjohn
- Feb 18, 2018
- dalarna
- Sweden
- Yamaha sr viper xtx se
hi, this is my first Thread here, first time viper owner.. the sled is an xtx se 2014 stock.picked it upp att a local dealer... sled has 930 Miles on it ,1020 km. i have driven 600km on it so far this last weeks.. i am in need of a little help. the sled is over revving /hitting rev limiter on launch in loose snow. should i add more weight/ rivets or get a softer spring? and how do you attach the bag behind the seat ? looks like im missing som knobs for the bag.
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
There are 2 nobs that are riveted on to the tunnel for the rear bag and the 2 straps go in the holes under the rear bumper.as far as hitting the rev limiter mine does also if I throttle it at low speeds.mine seems to rev high also at around 9200
hedjohn
- Feb 18, 2018
- dalarna
- Sweden
i am missing rivited nobs then. where can i find them? part number?There are 2 nobs that are riveted on to the tunnel for the rear bag and the 2 straps go in the holes under the rear bumper.as far as hitting the rev limiter mine does also if I throttle it at low speeds.mine seems to rev high also at around 9200
petey_sx700
- Nov 17, 2013
- Central, WI
- 2017 Sidewinder LTX DX
2017 Viper STX DX 146
2013 Vector
2018 SRX 120
- West Central Wisconsin
Stays 8JP-F8423-00-00 Rivets 8JP-RA516-00-00
MarkB83
- Feb 19, 2018
- Alberta
- 2016 SR Viper MTX 162 SE
2008 FX Nytro MTX 153 40th Anniversary
The reving out could be your clutch set up. I can’t post pics (spec sheet) but if it’s the same clutch that’s in my 2016 you need more weight at lower elevations.
Welcome here! Yes you need to add more wieght to primary. If it's at launch only put wieght in heel. If it's at top speed add it to tip.
