Fixed my a-arm bushing issue
LazyBastard said:
Make sure that your bushings aren't too well sealed. Grease guns output at several THOUSAND psi, which is no doubt several thousand too high for foam plugs.
There is .009 difference between the shaft and the bushings, that is .0045 a side. I think that should be enough clearance. what do you think?
just wanted to know if any one has used JB weld to fill the holes, Dexter and I are going to do it to his sled. I Will let you know how it works.
