xrayjohn
- Sep 28, 2010
- Frankfort, IL
- 2006 Apex
- Frankfort, Illinois
Just finished reassembling my 06 Apex and I am getting a flashing display on my instrument panel.
The owners manuel says it is possibly a disconnected wire on the fuel gauge sending unit.
Checked the wires on both ends - at the gas tank and at the wiring harness.
Any ideas?
Any ideas?
Not just low on gas???
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
Re-trace your steps. What did you disassemble?
xrayjohn
- Sep 28, 2010
- Frankfort, IL
- 2006 Apex
removed seat, gas tank and replaced doughnuts. Plenty of gas.
I just did mine a few weeks back and had the flashing error as well. It was flashing the fuel and it showed a full tank. I knew it only had a gallon in it. Turns out I forgot to plug in the fuel meter sender unit #*$&@. It is on the clutch side of the sled on the back side of the tank. It was a 5 minute fix. I hope this helps.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Is it possible that one of the fuel filters in the tank got tangled with the sending unit? Have a look in there with a flashlight.
LJ 452
vader2185 said:I just did mine a few weeks back and had the flashing error as well. It was flashing the fuel and it showed a full tank. I knew it only had a gallon in it. Turns out I forgot to plug in the fuel meter sender unit #*$&@. It is on the clutch side of the sled on the back side of the tank. It was a 5 minute fix. I hope this helps.
9 times out of 10 that would be it, the other 1 is no fuel in the tank.
Should be a connector right side of tank, facing the motor. Green plug if memory serves. Plug it in and restart.
xrayjohn
- Sep 28, 2010
- Frankfort, IL
- 2006 Apex
Thanks Vader. that did the trick.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
I think 'Vader' should use my avatar LOL
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
xrayjohn said:Thanks Vader. that did the trick.![]()
The guys in this site are the best! Always willing to help out!
Glad it was an easy fix!
I wish I could take credit for it but I did the same thing and posted the same question a month. Saved me tons of time and frustration. The guys on this site seem to know everything.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
and the person who told you probably did the same thing as well thats why this site works so well.vader2185 said:I wish I could take credit for it but I did the same thing and posted the same question a month. Saved me tons of time and frustration. The guys on this site seem to know everything.
