Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
Hey guy's I wear FXR boot (which I love) and I found last winter that my boot was to thick height wise for the foot well. Is there anything I could do to resolve this? Without buying another pair of boots.
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
what size of feets are we talking here?
Joshua
- Apr 14, 2010
- Newfoundland
14. Its not as much the length of my foot, its how thick my boot is
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Without buying, then just put Vaseline the clear stuff , Put it all over the toe area, then slide your foot in to the footwell. Or common sense buy thinner boots, cause it will cost more to make well bigger, higher. Just sayingHey guy's I wear FXR boot (which I love) and I found last winter that my boot was to thick height wise for the foot well. Is there anything I could do to resolve this? Without buying another pair of boots.
might be able to mod the upper side of the foot rests to give yourself more clearance.
Mtnviper
Vendor
I have the same boots and ended up removing the toe hold brackets on my Cat. The original plan was to modify the brackets for more clearance and reinstall them. However after a season of riding with them out, I haven't had any issues with snow intrusion on to the clutches so I think that I'll probably just leave them out.
I did reroute the speed sensor wiring harness and secured it with silicone, so that I don't kick it with my foot though.
Joshua
- Apr 14, 2010
- Newfoundland
Did this help with the height of the foot well?
Mtnviper
Vendor
Yeah, it made a big difference. I 'm a mountain rider and if I dumped the sled over while carving, my foot would get stuck in the footwell.Did this help with the height of the foot well?
Joshua
- Apr 14, 2010
- Newfoundland
That's my exact issue. Thanks a lot. One more question since i'm not in front of my sled, how did you remove the toe hold bracket?
Mtnviper
Vendor
They are just bolted in with 4 Torx screws. The screws were pretty tight and I did have to cut the head off of one of them in order to remove the bracket.
Joshua
- Apr 14, 2010
- Newfoundland
Thanks alot
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I have fxr size 14 also and part that really is tight is the right foot on the brake rotor cover and it pinches it off of if foot twists at all. Only ride trail so it may not effect me as much as you.
- 27K
