Forget how the skid arms go back together
ryan11007
15 xtx se viper
So for the rear shock there are 3 holes do u mount the shock on the first hole closest to shaft or middle hole? Bottom hole is the arm.
Pretty sure it's middle hole? Powder coated arms.
I believe you have it right in pic. Wonder what would happen if mounted in other? Does it hit anywhere?
Yea I believe it will hit just slightly because of the angle and the base of the shock. I should of just tried it before posting. Sure makes me wonder y they even made a hole.
