fast n furious
- Jan 24, 2010
- Nova Scotia
- 2008 40th anniversary apex LTX GT
Just put a set of fox float 2 on apex xtx, what pressure is recomended thanks
Berg570
- Nov 18, 2012
- Cle Elum, Wa
- Sidewinder MTX
Im in the same boat Fn'F!!!
I believe the factory preset was 50# on them.
fast n furious
- Jan 24, 2010
- Nova Scotia
I put 65 psi, thought i read that somewhere awhile back. any other experienced users of float 2? I ride pretty aggressively jumping boondocking etc
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
From stock they are set at 50# for a rider weight of 180-190#. From there you can fine tune them. I would start there.
Subaru2006
Subaru2006
fast n furious
- Jan 24, 2010
- Nova Scotia
thanks guys
I run 70 and although it's a little stiff but never bottoms. The revalving helps a lot too.
Cobalt
- Aug 27, 2006
- Greenville WI.
- 2012 Apex SE
55-65 is the sweet spot! I ride very aggressive and absolutely love this shock package! I had the Fox Floats on my 07 RTX and did not care for them at all but the ones on the 2012 Apex SE, along with the redesign is an amazing package! I also have a set of Snowtrackers, not sure if that is part of the reason I love the front suspension or not?
Bucky the d.o.g.
- Oct 8, 2007
- Ottawa, Ontario
- 2017 Apex XTX
I installed the Hygear piggyback resevoirs, I run 70 pounds on the ride height, and 170 pounds on the bottoming valve. Works well for me on fast trail riding, good handling. After that I will adjust the "bottoming" pressure based on snow conditions to improve handling(like the dual clicker GYTR'S). These Float 2's are a way better than than the original Floats.
apex55
Adjusted mine so the A-arms were just about parallel to the ground
