RX-1 Liter
- Apr 14, 2003
- Chautauqua County, NY
- 2017 RMK 155"
Has anyone out there had any real experience with the Fox Floats? I remember reading in Snowtech that they absolutly loved the way they performed (soft with no bottoming). What about reliability?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
a fella posted earlier that he had seen many of them on F-7's loose air pressure.
Tork
And if you look at the rough trail videos it looks like they work fantastic.
A lot of technology went into those.
Yamaha had them in their accessory catolog in 05 and now on all these sleds, they would not be doing that if they had not really tested these out over a 2 year period.
srx600
I had the front left one on my F6 sno pro loose its pressure on my last ride. I rolled my sled at the end of a field when i went to make an aggresive right hander and the track slid out and the sled went over...I'm sure have only 10 lbs on the front left contributed............I must say they ride AWSOME. Just a little leary if my front left will loose pressure agian during a ride. Most that i've heard of have lost pressure in very cold conditions ?????
Just my 2 cents. They will probably need constant adjustment as the air spring rate will change a lot with temperature. That includes during a ride as the shocks go from ambient temp to operating temp. I know from mountain bike evolution that suspension forks went from air spring to coil spring cartridge damped due to concerns of stiction and reliability of the air only setup. I think we share the same goals of performance and light weight as mountain bikers. If money was no object, I would prefer an aluminum bodied remote reservoir shock with titanium springs.
sledheadgeorge
srx600 said:I had the front left one on my F6 sno pro loose its pressure on my last ride. I rolled my sled at the end of a field when i went to make an aggresive right hander and the track slid out and the sled went over...I'm sure have only 10 lbs on the front left contributed............I must say they ride AWSOME. Just a little leary if my front left will loose pressure agian during a ride. Most that i've heard of have lost pressure in very cold conditions ?????
JUST GET A CAN OF TIRE INFLATOR FROM YOUR LOCAL AUTO STORE...USED TO FIX FLAT TIRES.......LOL
Yes, they do require constant adjustment. Like every morning you need to check pressures, and if you are riding hard in the rough they actually build pressure and therefore run stiffer. We a few F7's in our group sometimes and they also have been getting moisture in the seal which freezes and causes the shocks to go flat.
JDKRXW
Filling them with nitrogen will solve allot of the temperature / pressure increase with use issues.
RX-1 Liter
- Apr 14, 2003
- 2017 RMK 155"
Hmmmm....I was really leaning towards the RTX, but I think I will stay away from the foxes. Looks like the GT is the leader now.
jimmie d
GT by far, the RTX looks like a boy racer from Warsaw.
Jim
Jim
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
I have had buddies that had all sorts of fade problems with them on the f7's. I was told they are good for the average trail rider but if you drive like a caveman you would be better off with a set of ohlin piggybacks
pro tc
i have 950 miles on my 05 f7 and have had no pressure loss. thay perform great. but i have heard of people having pressure problems. im sure its a small percentage.
pro tc
pro tc
NY_Nytro
We have an 05 F7 SP in our group. He tends to lose some pressure over a weekend trip about 20 - 25 lb total on the last trip. It was very cold on that trip, well below zero F.
fstblkwarrior
My brother and I both have them on our mountain bikes. His are fox and he has to add air 1 time a week, I have Manitou and I add air 1 time a month. I think the way they ride is well worth it. It's easy to do a quick check before a ride. The technology has been around forever. Although Ohlins do make a sweet shock....
