So, I went to adjust the pressure in my Fox Floats today. Front off sled was off the ground. Attached the pump, gauge read 60lbs. Pumped up to 70lbs, removed the pump, and air just leaked out. I reattached the pump and there was no pressure in the shock. Reinflated and same thing happened. I pump up to 70lbs, remove the pump and shock completely deflates.
Anyone ever experience this before???? I've only ridden a few miles this season and haven't damaged the shock.
Thanks for any feedback!!
