SledFreak
- Feb 7, 2005
- Ontario. Canada
Will the Fox floats work from any of the AC sleds (ie. Fseries or X-Fires)on the FX Nytro? I really only want them for drag racing, so I can drop the front suspsion right down.
ahicks
The Apex Rtx shocks are an inch shorter (16.5") if that's any help.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Does it matter, if they are shorter for that matter, when I am only using them for that purpose and will they bolt up, if they are off another brand.
ahicks
The only difference might be in the valve stacks - or possibly in the width of the rubber bushings that come with them. No big deal either way?
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
your ride height will be incorrect and if you adjust with pressure, you might bottom them out sooner.
SledFreak
- Feb 7, 2005
- Ontario. Canada
25-30 PSI is all I would be running, so would it be OK?
NyTrOMaNIaC
A shorter shock would certainly make it easier to lower your sled. Only thing I'd be concerned about is attaching the sway bar (if needed), but it might not be an issue. Unless someone chimes in with experience, won't know until you try.
ahicks
I just wonder if the shorter shocks are even necessary.
You're planning on strapping the front and rear of the skid as well, correct?
Have you done that and checked to see how low the stock shocks will go?
SledFreak
- Feb 7, 2005
- Ontario. Canada
NyTrOMaNIaC said:A shorter shock would certainly make it easier to lower your sled. Only thing I'd be concerned about is attaching the sway bar (if needed), but it might not be an issue. Unless someone chimes in with experience, won't know until you try.
Sway bar moves with the chassis and A-Arms, I don't see it being a problem.
NyTrOMaNIaC
SledFreak said:NyTrOMaNIaC said:A shorter shock would certainly make it easier to lower your sled. Only thing I'd be concerned about is attaching the sway bar (if needed), but it might not be an issue. Unless someone chimes in with experience, won't know until you try.
True, I was just thinking about when the shorter shock rebounds compared to the proper length shock. I guess if it's lowered with little air pressure it won't matter. I take it you're going to borrow a set and try them ? Otherwise, you're better off just getting the proper 17.5" long shocks so you can use them everyday.
SledFreak
- Feb 7, 2005
- Ontario. Canada
NyTrOMaNIaC said:SledFreak said:NyTrOMaNIaC said:A shorter shock would certainly make it easier to lower your sled. Only thing I'd be concerned about is attaching the sway bar (if needed), but it might not be an issue. Unless someone chimes in with experience, won't know until you try.
That would be the plan...
bjowett
The length of the F series shock is about 17.5". The valving will likely be on the light side. The bushings will be the wrong width, too. Both can be solved, but you might be better off buying the correct shocks or trying something different.
