birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
I'm doing maintenance on my front end but is struggling a bit. To remove the cross shaft bolts on the A-arms on the chassis side, how do you get to the nuts to remove the bolts?
Also, anyone had difficulties removing the lower A-arm bolt on the spindle side? I even have difficulties turning the bolt...
Please heeeelp!!
Please heeeelp!!
spike337
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Yeah, looks a bit different
Do you remove the whole front section??
I can't do that on my Vector :-(
spike337
I usually don't get to worked up or worried about a non-rotating greasable part, but these were pretty much dry, (like the steering head of my WR). You spend a lot of money and expect Yamaha quality, sure wish they'd take more pride and jamb ten cents more grease in there. That would go a long ways!
I pulled the front, or split the sled, on purpose, just to try it, and it made it easier to get at some things that needed attention.
LJ 452
The nuts for the shafts are buried in the bulkhead. I think I had to remove the battery and tray to get to them. Once you've cleared the way it way fairly easy with std. open end wrenches. As for the bolt that won't spin, I can't remember if mine were that way, it may be bent and just binding, or it's just seized in there.
jamesc
you do have to pull the battery and tray assembly to access the nuts, only takes a few minutes
Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
for sure the bolt that has taken a beating and got bent.. just replaced the bushings in the spindlehouse,a-arms,bulkhead and the rest in the steeringcolum and only one i had problem with was the lower at the spindle at the left side..
It was bent, and the collar offcourse.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Thanks guys. I'll check it out!
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Thanks guys! Removing the battery did the trick!
Saved me a lot of time!! My new Barkbuster front-end is now in
Pics will come shortly in the 4-stroke Garage section.
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
We welded the nuts on the race sleds. That way changing the bent a-arms was faster
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Yeah, agree. It's the way it should been from the factory!!
LJ 452
On the FX chasis both Phazer and Nytro, the A-arm nuts are easy to get to on the 08' subframe, 09' and up, not so much. The gusset plates get in the way. The nuts can be welded on either of the FX sleds. The Apex however, the front bulkhead or frame, is CF. aluminum. So welding the steel nuts to the Apex is not really an option. But if you time your repairs correctly i.e. oil change you would be fine. I noticed when I had my Apex that most work was best done while doing the filter change. It always seemed like the same parts always had to come out anyway.
04JRB
- Jul 24, 2009
- Farmington Hills, MI (Metro Detroit)
- 2009 Apex LTX GT
I just went through this on my Apex. As said by others, I wish those nuts were welded from the factory too. Then I wouldnt have had to take half the damn sled apart. Well, it was about the same as an oil change, lol.
