kschitoskey
- Aug 22, 2015
- Central Oregon
- 09 Nytro XTX
07 Phazer
94 Polaris 440
Rookie question - how do you remove the plastic cover that goes behind the front suspension a-arms? Do I have to pull the upper a-arms?
I'm trying to adjust the steering after installing a steering post relocating kit, trying to access a pesky jam nut.
Thanks!
Thanks!
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
Jam nut on tie rod?
kschitoskey
- Aug 22, 2015
- Central Oregon
- 09 Nytro XTX
07 Phazer
94 Polaris 440
Exactly. Too tight for 14mm stubby...
radianguy
- Jan 1, 2007
Go in though the rubber boot! There's a plastic push rivet you can remove on the boot and you will have room to get at the jam nut on the tie rod.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
If you remove the belly pan skid plate the inner tie rod ends are easily accessible from the underside.
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
Once you remove all the hard plastic with the quick releases the rubber panels quickly slide down (see pic) just be careful the weight of the rubber panels which are actually two parts stress the one non-removable rivet into the chassis. My right one pulled out during my was in the pic so I have to re-install a new one...
