Jd2859
- Dec 2, 2019
- La Crosse,Wisconsin
- 2020 sidewinder LTX GT
ok guys I have a 2020 ltx se 600 miles on the sled changed the front spring to help get some weight off the skis and now im noticing the drive lugs are rubbing on the aluminum sleeves I have taken it all apart lower shaft is not bent and the bolt holes are not egged shape and slides are new I have talked to numerous people about this but im trying to get some more ideas what's going on before I take it to the dealer just to have them tell me they can't figure it out
rbig18
- Mar 4, 2012
- SR Viper ltx se
I couldn’t really see in picture but there is a curved bracket that attaches to cross shaft and shock. Many people install in the wrong orientation and it causes the problem you have.
Jd2859
- Dec 2, 2019
only thing I did was take top bolt out when installing it any chance you have a picture of what your talking about?I couldn’t really see in picture but there is a curved bracket that attaches to cross shaft and shock. Many people install in the wrong orientation and it causes the problem you have.
Are you sure its not just normal wear? The nubs will polish the sleeves above them just from snirt. If its a vibration or actually hitting either shaft is bent or holes in rails are egged out. That long bolt stretches and is a bad design. Its bit me too.
Jd2859
- Dec 2, 2019
Nothing is bent or egged out I have everything apart right now never noticed it till I put spring on if it’s normal for drive lugs to hit them sleeves I won’t worry so much but I just find it odd that it’s rubbingAre you sure its not just normal wear? The nubs will polish the sleeves above them just from snirt. If its a vibration or actually hitting either shaft is bent or holes in rails are egged out. That long bolt stretches and is a bad design. Its bit me too.
Are your slides really wore in that area? post a pic of it.
Jd2859
- Dec 2, 2019
Slides are brand new I replaced them to try that even though original slides had next to no wearAre your slides really wore in that area? post a pic of it.
Take a pic. Bet its just sandblasted.
Jd2859
- Dec 2, 2019
I have a pic posted where the drive lugs are rubbing on the aluminum sleevesTake a pic. Bet its just sandblasted.
Nobody can see that picture. At least I cant. Can you text me the picture? (920)3231973I have a pic posted where the drive lugs are rubbing on the aluminum sleeves
Here we go:
Your good. Normal wear
Make sure you use Loctite on that long bolt and torque. I recommend replacement with a Barn of parts shaft. Steel and two bolt.
