MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
Just wondering what the advantages of closing off the front tunnel is?
Mine is open and I haven't noticed any problems, but I will have my sled apart this summer and wondering if it is worth it?
Thanks guys,
Thanks guys,
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Mine is open and will stay open.
I think an advantage to closing it would be less ice build up. I had ice come from the front hole down the side of the tunnel to my running boards when I was riding trails with 20-30cm's of snow for a few days in a row trying to get the trails ready for the groomer to pass. That's the only time I have had ice build up and I was able to kick it off.
Maybe also adds protection from possible rocks or ice chunks hitting and damaging the exhaust?
A disadvantage would be heat under the gas tank. And for that reason I will deal with the ice the odd time it builds up.
marpolsdofer
yamahas said:Mine is open and will stay open.
They always suspect the ice damaging the exhaust.
I have had problem with the closer before. I had the stuff of the fuel tank melt to that underside plate. Everything was open to ventilation.
Wonder if it would be worth covering the hole with a piece of expanded metal, still allows spray and air to cool the exhaust while preventing ice chunks from hitting it.
Ruckus
4000 km on mine and zero issues. I beefed up my heat shielding.
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Ruckus said:4000 km on mine and zero issues. I beefed up my heat shielding.
I think this is the way to go. Add some header wrap, cover the tunnel and no more ice but you keep the exhaust cooler.
xt_gt
had both holes closed off before i had any miles on my sled. no issues at all.
just this last season when i had the rear section dismantled, i put on some header wrap that i had laying around.
I vote closed both holes but I do really keep an eye on all the heat shielding and have had to replace the fibre shields which arent cheap.Other than that 2 seasons no problems.
ef x eh
i have closed off both holes since new and have had no problems. 10,000 km and still goin.
- 17K
