nickbeen1982
I know I saw a post about this topic somewhere, but I can find it!
The sled is an 03 RX1 with Bender Rear Mount and an Italian made fuel regulator. Any help would be great! The intercooler was full of fuel and when you turn the key and the pump fires up, fuel pours out of all 4 carbs!
What broke?
What broke?
TT
Sent you a pm
chrisinparts
- Feb 10, 2004
- dearborn mi
- 05 rx1, 10 nytro, 10 z1 turbo
needle valves dirty and sticking open. best thing to do is buy new ones
nickbeen1982
THE PROBLEM WAS THE BOOST SIDE OF THE FUEL PRESSURE REGULATOR WAS FULL OF ICE. THIS WOULD NOT ALLOW THE FUEL TO RETURN TO THE GAS TANK SO IT WOULF FLOOD PAST THE NEEDLE AND SEAT AND FLOW EVERYWHERE! THANKS FOR YOUR HELP!
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Little bit of water, eh?
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
You have to wonder how much of that fuel got into the oil. I would change the oil before running it if it were mine.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Good point!!!!
nickbeen1982
Yes, I plan on changing the oil! I gentleman named Keith told me to drill two .004 holes into the lowest place on the intercooler manifold. This allows the water that is formed to constantly be purged from the system!
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Ah, kind of like drilling small holes in your head gasket to reduce compression?
nickbeen1982
This is a trail sled! 15lbs of boost is 15lbs of boost! Regardless of leaks! The turbo can compensate through the wastegate!
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
I've had this happen before. Are you using a pre-filter?
nickbeen1982
I wasn't using a pre-filter, but I just got one today!
- 7K
