AttakDog
Does anyone have the part number for the fuel pump relay? Is there a cross reference for an automotive relay? I'd like to get a spare to keep in stock, just in case. Thanks
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
i think this is it....not positive though.
EDIT:
4 relays above left foot....
One is 5DM 81950 00 00 for headlight
8FP-81950-01-00 is other 3 relays including fuel pump/injection.
Dan
EDIT:
Dan
AttakDog
Thanks Dan, once again you come through for me!
apltx08
I pretty sure its 8FP-81950-01-00, I was checking the wiring diagrams, the 1 Dan mentioned is for the Headlight and the 3 others are all the same as Part # I mentioned...(FI,Load Relay and Rad), sled relays are as follows, from gas tank or right to left, Rad Fan/Load Relay/Headlight/Fuel Injection.
johnketch
i just ordered two of them today.AttakDog said:Does anyone have the part number for the fuel pump relay? Is there a cross reference for an automotive relay? I'd like to get a spare to keep in stock, just in case. Thanks
eight bucks each at the dealer.
big guy
Thats the part number on my receipt as well 8FP-81950-01-00 Pump Relay.apltx08 said:I pretty sure its 8FP-81950-01-00, I was checking the wiring diagrams, the 1 Dan mentioned is for the Headlight and the 3 others are all the same as Part # I mentioned...(FI,Load Relay and Rad), sled relays are as follows, from gas tank or right to left, Rad Fan/Load Relay/Headlight/Fuel Injection.
AttakDog
OK thanks to all!
big bear-apex turbo
i have to get a new one today as well. mine is broke down because of that but know i know
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
sorry i typoed....i have both of these written down from yrs ago correctly just typed in wrong one,sorry bout that.
8FP-81950-01-00 is correct.
Dan
Dan
meatman
- Apr 14, 2009
- Fort Saskatchewan , ab, can
- 2017 Yamaha Sidewinder XTX
fuel relay
do you have the order or the relays for a 09 nytro xtx, i have a battery drain issue and it is possible that the relay is sticking on i have located them in the nose under the steering post. there is one then the lighting one then 2 more. i have already picked one up just need to figure out which one to switch. thanks
happy holidays
happy holidays
