Was reading my manual last nite and see it suggests you trailer with an empty fuel tank to reduce the chance of fuel trickling into the carbs and then into the crankcase. Someone suggested on here you install 2 shutoff valves on the 2 fuel lines. My question is,
on the turbo's with a fuel pressure regulator and an electric fuel pump, are shutoffs necessary?
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
No.
I guess since Lakercr is the only one who knows but is in the expert category, he must be right.
Mikey
- Thunder Bay Ontario
- 03 RX-1
Find out for yourself and disconnect the fuel line after the pump and see if any fuel leaks out if it dosent then simulate trailering by rocking the sled around and see if any drips out onto a rag. I myself fail to see how fuel could leak past the impeller inside the pump tho....
Buckeye
- Lakes Region, NH
I agree with Lakeracer.
spray25
lakercr said:
Sounds about right to me.
