Full Size Clutches on Venom
cannondale27
Staff member
Moderator
Vendor
Manitowoc,WI
I had primary from my 13 RR that Thunder Products went through and picked up a new small fin secondary. Will be aligning needed and haven’t checked if electric start will work since I don’t have a ring gear. But they both fit perfectly. Same taper in Primary and same spline and shaft arrangement in secondary. Will set them up permanently in off season. Should work well!
