I advise printing this pic and either put it in fuse box cover or manual if you carry it with you. With this you do not have to remove hood to see and access the fuses. Bigger handed folks may have a issue but fuse box cover can be removed through sidepanel. You are working blind though. This will help find the one you need.
To me all the relays look to be sealed but definitely not solid state.
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
Thank You for the pic. Printing now.
sk-rx1
X2
Curtis Chambers
- Nov 19, 2014
- 2015 SRViper R-tx-Le
Good idea cannondale27, will do, thanks
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Thanks.
Very helpful
Very helpful
Tunepipe
- Oct 5, 2014
- Sormany
- VkPro, Venture TF, Phazer, Snoscoot 200...Sidewinder, Excell III
FYI taillight fuse is also accessory and dash.
sneakattak88
My relays froze againnnn, second time, dealer says no recall, and yamaha says i be the first ,, grrrrrr
Tunepipe
- Oct 5, 2014
- Sormany
really surprised, havent came accross any freezing relays in the last two years on Vipers...buy a lottery ticket ) Are you sure its the relays ?My relays froze againnnn, second time, dealer says no recall, and yamaha says i be the first ,, grrrrrr
sneakattak88
yep , warm them up, and start right away
Tunepipe
- Oct 5, 2014
- Sormany
so it turns over but doesn't start ? have you swapped relays ?(used another one for the fuel pump)
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
If it just cranks and cranks with out actually starting then i had this issue earlier this year also.
I started the sled, loaded it into the trailer. Dragged it a few hours to the trails. Went to unload it and it just cranked and cranked. No start.
I tried like 5 times. Just kept turning over. Never caught.
On the 6th time it started like nothing ever happened.
I was thinking probably a frozen relay and the repeated on off clicking eventually freed it up.
Okay and I am confirming. These are definitely NOT solid state relays. The click is dead give away. Solid state like the new red Yamaha one does not click since it has no moving parts. Sneak attack do you ride alot of powder? Get alot of steam? If so I would suggest reversing the fan polarity. Is a experiment some of us are trying and havent warm weather tested yet but you will not have your relays steamed with it reversed. I also dielectric greased the seal for fuse box. Helps seal and cover comes off much easier.
sneakattak88
yep cranks cranks , take heat gun to relay area and boom it starts
Taillight,Accessory and dash I checked. I added both to the Pic. Thanks for pointing that out. That could definitely be one to pop if a helmet cord grounded especially. It does still run without dash lit up. Any other odd things guys?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I got a bit of snow in the 12v jack when plugging in my heated cord this weekend and it shorted out and blew fuse. I wasn't going to worry about it until I realized the dash was dead! Poor design if you ask me.
Figured just change fuse but could not get my hands in to pull them nor can you even see them. Had to pull hood just to getto fuse. No way I could do this on trail. Luckily we were just leaving camp.
After all this I am working on a relocate kit for for the fuse block to make them easily accessible! I do intend to offer these for sale once finished.
