PowderFalcon
Pinnin' it!
Thanks fatchance and other replies, I don't have the dash flash, just the GAP module with tune bundles loaded. Was just thinking it might be wise to keep it concealed and pull it out as needed. I run SM tune bundle at 240 primarily, and it suits me just fine for an old(er) guy with a healthy sense of fear and common sense! lol.
Cheers
Only need when changing tune fella! Store it in your goggle bag and sennnnd it! Should probably run 270 though, just sayin' !
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I have flash to pass and data logging, plus I like the "Dashboard" on my phone so I keep it plugged in while riding. I have experienced the flasher drain my battery so I leave it plugged in for my multi-day trips but since My sled spends part of the year in Maine I keep the flasher with me so I can update when ever it may be prior to meeting up with my sled again.
I was offered to buy the replacement for $200 from Gap and that seems to be my best option. I wish I knew why I've had to replace 2 of them.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I put a piece of electrical tape over the computer cable port to keep moisture out.
I leave mine plugged in while riding.
I Bluetooth it to my tablet and use the dashboard to switch tunes and also look at the sensor readings. Nice big numbers.
actionjack
- Apr 9, 2005
What is this micro card chip reader? Is that in the flasher tool? How did you change it?I also have the dash flash and have never left the flasher connected to the sled other than to update the flasher and add new tunes. Last upgrade was the closed loop and the flasher would not update to the latest firmware so ended up needing a new micro chip card reader and then it worked. Just curious how much a new flasher would run me if I were to have problems in the future. I have the 240,270,300 SS juke box,dash flash, anti lag,closed loop and also the flash to pass button. I would prefer to not have the flasher plugged in most of the time.
Only time mine has been out of the sled is to update the tunes then right back in. I'm with you Tim, it's nice and easy to see those great big digits on the iPad. Takes allot less time to see so i can keep my eyes on the trail.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I do the same. Tape over the cable port. I never take it off my sled all year, only in the summer.
hman4
- Sep 22, 2014
- 2010 Apex, 2002srx, 2000 srx
Yes the micro chip card is inside the flasher. Had to open up the flasher kind of like replacing a battery in a key pod for your vehicle. Doesn’t come apart that easy.
actionjack
- Apr 9, 2005
Hmmm. Once my new one arrives and is working I may dissect the old one. In light of our mail issues here, I am astonished this thing is waiting at my house one day after Gap sent me a tracking number.
cjr
- Jan 28, 2018
- Old Forge
- 2018 Sidewinder 2021 sidewinder xtx le 146
Installed Hurricane close loop last week, now flash to pass works when it wants to and anti lag does not work at all. Settings show that they are activated, any ideas? Can use some help, thanks.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Wish I had all those problems, do you ever ride?Installed Hurricane close loop last week, now flash to pass works when it wants to and anti lag does not work at all. Settings show that they are activated, any ideas? Can use some help, thanks.
cjr
- Jan 28, 2018
- Old Forge
1000 miles so far you
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Did you unplug the A/F module power and flat plugs prior to flashing in the closed loop programing? I've heard not doing so can corrupt the flashes.
Otherwise Anti-Lag now needs to be enabled on the phone, but it sounds like you've already done that.
cjr
- Jan 28, 2018
- Old Forge
Yes I did unplug af phone app says anti lag on
KnappAttack
- Feb 19, 2004
- Welch MN
Did you try altering the anti lag parameters and save them to default at all? Id try that to see if they stick and become active. I wonder if you're losing connection to the switch off the bottom of the flasher? Or is the button going bad suddenly that tune switching is not working.
Now that I think about this, if the button is not working to switch tunes, it is not going to activate the anti-lag either. Could be a common issue, bad button or bad connection to the button.
