Fleecer
- Jun 13, 2014
- 2019 SRX
YES TurboR now as well. View attachment 174412
One of my past sleds had that cable which ran it up to the goggle bag which is where I stowed the flasher.
NYTurbo
So that isn't the connector that would plug into the communicator. Looks more like the extension to the O2 sensor or yes the plug for the flash to pass kit
ITs an extension cable and yes your flasher cable plugs into it, not the AFR module.
First glance had me fooled. My bad
earthling
Does the flasher plug into the diag port?
NYTurbo
Yes
earthling
So the same connectors and wiring is required for the EPS upgrade. Based on that, it would be easy to put the flasher anywhere.
no1b4me
You can use any OBD2 extension cable and route your flasher to your preferred location....ez peasy and cheap ....amazon it ...
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Bob, did you happen to try acetone or like product on the actuator cover plate before installing Velcro?
sideshowBob
Yes I did on the initial install of the velcro on the reverse actuator shield and I even heated it slightly with a heat gun to activate the glue. Could have just been a bad batch of velcro...Bob, did you happen to try acetone or like product on the actuator cover plate before installing Velcro?
Doc Harley
- Oct 17, 2016
- Here & there
Who knows?!?! I use that "I lock" grade. Seemingly uses a pretty stringent adhesive.Yes I did on the initial install of the velcro on the reverse actuator shield and I even heated it slightly with a heat gun to activate the glue. Could have just been a bad batch of velcro...
But I'll do as you, clean it, heat it and stick it....see how it goes.
I'm pretty sure I've seen other posts here in the past where guys are sticking it right to that cover, but never followed up to see how it's going.
no1b4me
Mounting on actuator cover ,hit it with 400 grit ,wipe clean with alcohol and apply velcro...works everytime ....aluminum cover is too smooth to get a good adhesion bite ...
Doc Harley
- Oct 17, 2016
- Here & there
Thank you that's the route I'll goMounting on actuator cover ,hit it with 400 grit ,wipe clean with alcohol and apply velcro...works everytime ....aluminum cover is too smooth to get a good adhesion bite ...
no1b4me
Look again .....the flasher is OBD2 the extension cable goes in between the flasher and the GAP conversion cable to CAT diagnostic connector
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I had mine ty-wrapped to the reverse actuator and it come loose and ended up under my header. It melted the casing bad and even part of the circuit board. Still works though lol...I am curious how and where everyone is mounting their Gap flashers.
I have been tie strapping mine just in front of the chaincase reverse actuator but last year it migrated too close to the heat from the exhaust and actually melted its casing a bit...fortunately it still works fine but now not so pretty.
NYTurbo
2 ways to skin a cat here , never thought of the OBD2 extension cable but yeah you’re rightLook again .....the flasher is OBD2 the extension cable goes in between the flasher and the GAP conversion cable to CAT diagnostic connector
- 46K
