stephenpen
I pickup an apex with a mpi kit on it. The kit is using a Gems fuel controller for a piggy back. I have an RB3 I'm not using, should I use it instead of the gems unit.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
How does it run on the GEMS? I am one of the few that like the GEMS its simple, works good, and safe. Its not perfect and I could adjust my AFR at different points a little bit better but since I set it two years ago I just ride now. No tweaking on it. at all.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
use boost it with external injectors
stephenpen
I'll let you know when I ride it saturday. The machine has been running good with it for the last two years. If I don't have to spend the money on the rb3 wire harness I won't. I know its running good now so I'm a little worried about starting over with a new system.
347strokin
stephenpen said:I'll let you know when I ride it saturday. The machine has been running good with it for the last two years. If I don't have to spend the money on the rb3 wire harness I won't. I know its running good now so I'm a little worried about starting over with a new system.
I would stick with the GEMS if you have it set up decent and it has been reliable. I have run both and if I did it again I would have just stuck with the GEMS. You will see increased fuel economy and the sled will run crisper if set up right on the RB3. Another nice touch is having two fuel maps setup: 1 for low elevation, 1 for high elevation.
The only thing I would do if sticking with the GEMS is carry a spare unit. Nothing ruins a day like a wet GEMS.
Ski-Dooin' it
yep...TURBLUE said:use boost it with external injectors
forget the piggyback, and rb3 is more then 99% of people need to play with.. do it right.
Adrenaline Addiction
Boost-It and dont look back !!
347strokin
I just realized you already have an RB3. I would use it for sure if you've already got it. Works very well when set up right.
SpeeDWerX1000
Ran 26# of boost on a stage III MPI with a GEMS, it ran great. Never got to test it back to back with an RB3 for comparison, but the GEMS worked good.
quebecmoutainrider
once you get it tuned..forget it..and then you have a high and a low elavation...I m happy with Gems
stephenpen
Is there a 10# flatland tune available for the RB3. I need something to get me started.
